Injector cleaning voltage
Hey guys,
New to this forum with a 914. I have a 71 914 1.7L that I want ready for this summer. I have removed my injectors to clean them. I am pretty sure they are clogged and need a good cleaning. Got new seals to replace as well since I have them out. Getting good gas pressure to them but no gas to plugs. I don't want to burn them up so what voltage should I use to activate the injectors when spraying my cleaner. I have heard 12v is to much for these. Thanks in advance. Jason (aka surfdogskier) |
914 Geek
Are you cycling them or just leaving them open? I think they can probably handle more voltage if you cycle them.
Your question is likely answered in Brad Anders' D-jet Bible. It appears that the voltage across the injectors when they are being held open is about 4 to 5 V. So you should be fine providing that. Note that it might take more to open them initially. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Thanks for the response. I was just going to cycle them. I read somewhere that a lower voltage was better. Just wanted to run it by you guys. Didn't want to over do it. I don't know for sure if they are clogged but a good cleaning was definitely needed. Been sitting for a while. Figured I would start there.
Thanks again!
1972 914/4 1970 Toyota FJ40 Landcrusier 1999 Lamborghini Diablo (build) |
