Gaskets for OPRV
I'm doing my oil cooler seals and I forgot to get the gaskets for the OPRV. The gaskets on it are the flat kind. I wanted to know if I'm able to replace the 2 seals with regular O ring gaskets?
GO AWAY! Stay in Cali
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/75549-oil-pressure-relief-valve-o-rings-2.html#post10086506
This is my OPRV. It fell apart durring removal and shreaded the gasket that goes inside the hollow portion. I replaced it with a regular oring gasket.
![]() ![]() ![]() Sent from my SM-G920P using Tapatalk |
To clarify the gasket I replaced is the bottom one that sits in the bolt, I don't have the OEM gaskets on hand and was wondering if I can just replace them with regular O ring gaskets. It apears the original gaskets were flat or maybe these are just worn.
