Decklid Glass Separating from Frame
The glass of the decklid from '87 944S has separated from the frame. It leaks slightly in the rain. Any ideas?
944 addict
Easiest answer: buy another one and stop using the struts holding it up. The frame is soft aluminum and the adhesive degrades over time from UV. While it is closed, the pistons are constantly forcing the glass away from the forward attachment of the hatch. Consequently, the forward part of the hatch separates as the soft aluminum frame deforms and the seal is lost. Without the piston struts, you don't have that aftward stress on the hatch. I see replacement hatches on ebay and craigslist frequently for 2 to 3 hundred. Efforts to reseal these hatches are marginal at best, especially if they go back to using the struts. A simple wooden mop handle works fine. Good luck in your search.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
I can totally see your point on the hatch struts! I'll disengage them to stop the separation from going any farther. I'll also keep an eye out on eBay for decent hatch glasses that are willing to be shipped.
In the interim, I think I'll just seal it with black latex. Has anyone ever tried removing the assembly and tapping the frame back in place with a rubber mallet? That's more curiosity talking... |
In the Fires of Hell.....
What I would recommend:
Use the primer on the frame and window, and let it cure for a couple of days before putting any stress on it...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Thanks, kdjones2000! That's certainly a cheaper repair than a brand new hatch glass. What would you recommend for getting the frame back into position?
Read up on here and Rennlist about resealing your hatch. It's a LOT of work.
You can either do the full reseal, or take a chance and use that stuff just in the separated areas and cross your fingers.
Duly noted...
This is one of the most common issues with all 944's. Replacement hatches may have the same problem.
Gone but not forgotten: 1971 914 First Car (SOLD) | 1972 914 rust bucket (SOLD) | 1986 944 Turbo (Murdered by a Chevy Truck on the freeway) Current lineup: 1990 944 S2 Cabriolet - Long term project | 1971 914 - Long term project #2 | 1971 914 - Driver |
Yep, my original hatch had that, and I scored another one 6 months ago that was in good shape. I "injected" additional urethane into the top of the frame to try to pre-empt this one separating as well, at the time.
After I saw this thread I happened to glance at it on the car, and damn if it hasn't separated as well (perhaps taking it on that rallycross course a few weeks ago did it, lol). I detached the support pistons and managed to push it back together to some extent, and it seems to stay that way as long as the pistons aren't on there. So......now I'm just gonna use a 3-foot dowel to hold it up. Bye bye pistons. |
I drilled the pistons and use a walking stick to hold it up.
Glass guy told me my first repair was because I didn't use the primer. Second repair held a little longer. Struts are the culprit. Race car people put a piece of Gaffers tape across the top. Doesn't look to bad and is a replaceable seal
I wonder if there are any electric struts that would work instead of the gas filled ones... no more constant pressure causing the glass separation, and you also possibly get a remove hatch. I wonder how much work would be involved in making this happen.
1987 Black Porsche 944 N/A |
I cut a piece of satin black wrap to the shape of the top of the hatch and the black interior decal strip and stuck it on the outside over the black aluminum and about 3/4 of an inch down on the glass. Looks original and stops the water entering. So far has lasted a couple of years.
1987 944 Summer 2006 E90 Winter |
I have glued several 944 rear hatches with little success its hard and u need about fifty small clamps get all the old material out the best u can acetone the glass prior to using the primer for 3m adhesive no guarantees but a strip of electric tape keeps the water out and doesn't look to bad if you trim the ends at a good angle
This problem drives me crazy, I want the hatch to open without a stick!
On a cheaper way, wouldn't using a bent square washer like on a screen door work to hold the shock open? Slide it up to lock? Also, it seems there should be a folding arm like on a rooftop camper, if you could find one stong enough. I keep looking. |
Hatch Stay
A piece of rigid 1/2" plastic pipe, cut to a 'C' shape, placed on around the hood stay rod works well on my 912. It weighs practically nothing and cannot be accidently knocked out. I don't know how well it would work applied to a 944/951...
Peter
Drill a small hole in the stick and use a piece of nylon cord to tie the stick to the hatch (there is a square bracket to tie it to) so when you open the hatch the stick pops up with it right in the correct place. I got the idea from my golf bag stand.
Got a pic of that?
Novarolla-Miata-Trooper-Jeep-Volvo145-Trooper-Ranger-MGB-Explorer-944-Fiat124-Alfa164-XTerra |
This is patented, I remind you!
