1989 944S2 Compression Test
This is my first time doing a compression test on a car. What would you read into the following results or have I done it totally wrong.....
Warmed the engine up to operating temperature at an idle and not for a 15 minute drive/blast as is recommended
Performed a dry test on the motor with the throttle open and all plugs removed
Results as follows #1-170lbs, #2-175lbs, #3-170lbs, #4-179lbs
Results with oil added (from a squeeze bottle so amount was not uniform) #1-205lbs, #2-205lbs, #3-200lbs, #4-200lbs
Thanks!
Old 08-23-2018, 09:34 AM
This is an excellent compression test, since your pressures are all high and well within the desired 10% maximum variance between cylinders. Your cylinders only have a maximum of 5% variance from highest to lowest when dry and a maximum of 2.5% variance when wet . HTH
Old 08-23-2018, 11:55 AM
So the variance from Dry to Wet is not something to be concerned about? I did notice a bit of oil soot on the number one sparkplug. Not serious but there. I was recommended to move to a thicker oil.
Old 08-23-2018, 01:03 PM
9FF 9FF is offline
9FF's Avatar
You should do a leak-down test as it will compliment your compression test results by providing details about your valves/guides. Imo your oil in the cylinder is most likely from valve seal wear and not because of cylinder wear, thicker oil won't improve anything.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 08-23-2018, 01:26 PM
TibetanT's Avatar
Agree with 9FF 100% !
How many miles on your 944S2 ?
(Wondering about that fact since I am about ready to test my car with 150K miles on it.)
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 08-23-2018, 05:55 PM
Tags
944s2 compression test
