Wow!
What a relief!
What happened to the alternator? And how?
If anyone wants to contribute to a separate ongoing oil analysis thread, I’ll help - since I brought it up. I actually already put a couple up here but it didn’t go very far.
Good thread!
Old 02-14-2019, 08:52 AM
Tired Member
DaddyGlenn's Avatar
Originally Posted by Bukowski View Post
Wow!
What a relief!
Good thread!
No idea yet. The alternator is still charging so, my son is driving it home tomorrow. Assuming he makes it, LOL, we'll have the old one off tomorrow night or Saturday. I will report back.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 02-14-2019, 03:40 PM
Tired Member
DaddyGlenn's Avatar
Alternator kept charging (and making noise) until my son was 4 hours from home.
Then it seized.
I grabbed the new alternator and tools then headed toward him. I had him cut off the alternator belt and drive toward me, turning off anything that would use electricity. Fortunately, being cold, we didn't have to worry about the radiator fans as long as he was on the highway. We were racing the sun.
When we met, I turned around and followed him. He had to stop for gas. I figured the battery would be too drained to start. I was wrong. We made it home without incident and before the sun went down.
The next day, we installed the new alternator and did an oil change. Then back to school for him.
An oil sample from the oil change has been sent to Black Stone Labs.
So, it was a bad bearing. My son had installed the alternator last October so it is still under warranty.
Glenn
Old 02-21-2019, 05:02 PM
Coeur d'Alene, Idaho
Nice outcome!!
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 02-25-2019, 05:51 PM
Patrick
pfarah's Avatar
Good to hear that it was only the alternator.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 02-25-2019, 06:15 PM
My wife's Outback was making a similar noise and I was sure it was a rod bearing. Also turned out to be the alternator. We sometimes right away think the worst instead of hoping for a better outcome.
Old 02-25-2019, 06:22 PM
Tired Member
DaddyGlenn's Avatar
And here is the oil analysis.
Glenn
Old 02-27-2019, 06:16 PM
Thanks. So do you have the stock air filter on it, or did someone install an aftermarket type on it?
Old 02-27-2019, 09:00 PM
Tired Member
DaddyGlenn's Avatar
Stock air filter was changed prior to this oil. No engine work since I replaced the oil cooler seals, 18,000 miles and 3 oil changes ago.
Glenn
Old 02-28-2019, 05:03 AM
87 944 NA
Old 03-11-2019, 08:12 AM
UkrainianVlad's Avatar
The stock air filter has oil stains on it though from the leak so that might contribute idk, also sup dad
Old 03-11-2019, 08:36 AM
Tired Member
DaddyGlenn's Avatar
Hi Vlad. That oil on the filter isn't bad at all. It is coming from the AOS. We may need to clean it at some point. But first, I'd like to do a compression check. If the piston rings are not sealing very well, we might be getting extra blow by through the AOS and perhaps piston wear. A compression check might give some clues.
I'll add it to the list for this summer. Anyone else have ideas/suggestions?
Glenn
Old 03-12-2019, 06:14 PM
