coupe's Avatar
Question Water temp. jumps when operating seat switch
This sounds like a bad ground somewhere in the instrument cluster panel. Have any of you experienced this phenomenon?
The temp. unit also seems to be very sensitive to minor temperature changes, perhaps the temp. sender is on its way out.
Is the temp. sender/transmitter located in the water pump housing?
Thanking you all in advance
coupe
http://www.p-caronline.com/directory/coupe
Porsche 944 Turbo, 1986
Fiat Coupe 20v Turbo, 1997
Old 03-15-2003, 07:41 AM
Ornery Bastard
My temp guage jumps up about two needle-widths whenever I have the lights on. When I get home for the summer the first thing I'm going to do is clean the grounds and check the sender.
Not sure where the sender is actually located though.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 03-15-2003, 11:47 AM
coupe's Avatar
I think I'll remove my instrument cluster again, 3 minutes, and check for a bad contact. As I remember now, It did get better one time when I removed the cluster and then refitted it.
coupe
Old 03-15-2003, 08:40 PM
AFJuvat's Avatar
Hey
remove instrument cluster.
if you look on the back of the cluster, you will see a couple of black rugby ball shaped fittings held on with a nut
remove them and clean them
should take care of the problem
double check the sensor - it is on the block, in the front, right under the coolant return.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-15-2003, 09:50 PM
coupe's Avatar
Thanks AFJuvat, I'll try it this morning..
coupe
Old 03-16-2003, 08:23 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
What's a rugby?
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 03-16-2003, 10:02 PM
coupe's Avatar
Rugby same as American football, only the Rugby players don;t wear
shoulder pads, ect...
coupe
Old 03-17-2003, 02:06 AM
