Is all year 944/924/968 have same Windshiled?
broken front windshild need to replace but I am not sure if all the years are the same
please let me know thanks |
I've been told the shape is the same.
Later models require the radio antenna laminated into the plastic safety layer between the two pieces of glass. The only difference between the early and later 944's is the plastic spacer and rubber trim strip. So if you stick one of those stubby antennas in the back center roof you can use the cheaper windsheild.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
