-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   side view mirrors (http://forums.pelicanparts.com/showthread.php?t=10242)
NoVA944 07-09-1999 01:06 PM
side view mirrors
On both of my side view mirrors the glass has fallen out. Has anyone else tackled this small but anoying problem. A friend recommend I put them back on with 3M molding tape. I would think that using the tape would allow it to vibrate and not give a very good reflection. I thought about using some two part epoxy, but before I venture there I figured I'd inquire here first. Any suggestions?
paulhagedorn 07-15-1999 11:33 PM
Now that it is a while later...
I have had to do the fix. At an automotive parts store, they do make some kind of glue that is for readhering the side mirrors. I had the fix done for over a year without any problems.
If I can find out what I used I will post that later.
Paul
NoVA944 07-16-1999 11:20 AM
Thanks for you the reply. After many inquires it turned out that I had to revert to the 3M double faced tape method. It worked great so far. No vibrations, very solid. Thanks again.
Rob.
