1984 944 hood insulation
My hood insulation on my 944 project car is shot. Can I drive the car without it or will it damage the paint on the hood?
Misunderstood User
Yes you can - You could replace it with a set of pad from Classic 9
http://www.classic9leathershop.com/ There are plenty of posts on how to remove the old insulation. If you chose not to, its ok
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
They sell them here at pelican also
Its a very low budget car. Can I run it without the insulation?
Is the engine a lot quieter with the insulation? Mine does not have it...so just curious...
Thanks, M
924S - 1988 |
factory started leaving the insulation off around 89 or 90 IIRC.
ive not had it since 2011, no issues with paint. |
In the Fires of Hell.....
My '88 951 never had the insulation...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Have 944, will restore
I've had 944's with the original insulation in place and many without it and i can honestly say that I did not notice much of a difference in sound or heat transfer with the original foam in place. My current 85.2's insulation has been gone for a long time, likely many years before I purchased it in 2013. I have never noticed any ill effects from not having it.
85.2 944 Guards Red M456 5spd 85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd 84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary 04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd 84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE |
My 88 924S has never had insulation since I've owned, and there are no signs that it ever did have it.
Nice use of a 5 iron......
..guess I'll not worry about mine not being there...M
924S - 1988 |
yes, I know the feeling...struggling a bit myself!
M
924S - 1988 |
Hood struts are pretty cheap and easy to replace. Something I wouldn't wait on, haha. The hood isn't light.
