951 Turbocharger Rebuild - What Else to Do While You're In There
Hi...
I'm about have my '87 turbocharger unit rebuilt. Some replacement things to do seem obvious: install fresh o-rings and crush washers all around and replace aging vacuum lines under the intake manifold. I also plan to install a new AOS with new o-rings. B
Because I'm new to the 951, I'm looking for guidance on what else should be done while I'm in there. For example, would your recommend replacing the turbo's oil feed and return lines and the vest line rather than cleaning them. Given the amount of time necessary to get to the turbo, I'd hate to miss doing something
Thanks for any insights you can provide
'87 951
'01 986S (Sold)
'78 924 (Carburated; sold when moving to CA)
Old 01-11-2020, 09:51 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Check your power steering unit for leaks. It has to come off for access to the turbo anyway. Also, replace the AOS seals and look for leaks from the clutch master cylinder. It's hidden under the Power Brake unit and hard to see otherwise. Have fun.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 01-11-2020, 12:50 PM
