89 944 relays
Is there something that lists what each relay is for each location? I need to make sure each of my relays are in the correct location.
944 S2
Fuse box cover?
Clark's Garage?
Sent from my SM-N950U using Tapatalk |
Caraquet,N.B. Canada. |
Thanks for the help. I have a fuse box cover and has the relay and fuses on it, but is does not call out what each relay is- i.e. double pole double throw, single throw double pole, integrated circuit, etc. I am also curious if anyone has the part number for each spot. There are two I am most involved with at the moment- they are called out as 18 and 19 on my 1989 944. They are called"alarm" relays. These relays need to be activated so that I can get power to the circuit the feeds me brake lights. I am trying to verify they are the correct type of relays
The wiring diagram for the Central Electric (Sheet #11) shows exactly what each relay in the fuse box has for contacts and circuits.
Here is a jpeg of the last part of that sheet, showing the two alarm relays.
Good luck, George Beuselinck |
