hoff944's Avatar
Send a message via AIM to hoff944
@#!%* !!! HELP!
I'm trying to install my test pipe. I have a problem that is pissing me off! There is a particular bolt connecting the pipe to the header and a 12mm is too small but a 13mm is too big. Its also damn near impossible to get it on the bolt. I've tried everything I can think of. Now everytime I go through my garage, I see the test pipe and its like its laughing at me For those of you that have installed test pipes or downpipes, can you help me!?!?!?!?
signed,
I'm Begging.
Old 08-08-2000, 07:16 PM
lm6y's Avatar
It sounds like someone has changed a bolt with a Standard bolt. Has this car had a clutch put in? That could explain how it could have gotten changed. Any way, try a 7/16 wrench, if it fits, it's been changed. The worst that could happen is break, or cut the nut off and replace it. One thing that helps is, use a long extension, a universal joint and a socket to remove the bolts. It worked great for me.
Old 08-08-2000, 07:41 PM
Try your teeth...
Old 08-08-2000, 08:03 PM
hoff944's Avatar
I tried my teeth but I got too much rust on them.
Thanks for the advice. I'll try it tomorrow. I tried metric and standard but I didn't use a 7/16 I don't think. I don't know! This has racked my brain because I thought it would be easy. I also used a universal too. I may have to cut the bolt off. This will not beat me!!!! I'll take any other advice anyone wants to give too.
[This message has been edited by hoff944 (edited 08-08-2000).]
Old 08-08-2000, 10:58 PM
Send a message via ICQ to porscheboi928s/c944t/n
nigger rigged it!!!!..1/2 INCH BOX END WRENCH...WHAT ABOUT METWRENCH??IF NOT...YOU GOTTA DO WHAT YOU GOTTA DO....ALSO THE BUTT CHEEK IS A GOOD IDEA......(J/K)
Old 08-09-2000, 12:26 AM
Old 08-09-2000, 12:27 AM
hoff944's Avatar
The beast has been slayed!!!!! I was using the right size on the one bolt I was having troubles getting to, but I wasn't getting the right angle. I had a similar incident on the next one but I used a 1/2 standard to get it off and all of the rest were 13mm. Thanks for all the advice guys. I'll be back if it rears its ugly head again.
Old 08-09-2000, 11:36 AM
Banned
As a person of color and a parent, I am offended with choice of language used in this particular string. Lets try to keep it clean, please...
Old 08-09-2000, 01:49 PM
Yeah, leave that kind of remark where you found it. It has no place here.
Old 08-09-2000, 02:39 PM
Never mind. I deleted this comment because I didn't see one of the earlier comments on the thread.
[This message has been edited by LtUSMC (edited 08-09-2000).]
Old 08-09-2000, 02:56 PM
Banned
mideastmafia, you just dont get it....
Old 08-09-2000, 04:26 PM
hoff944's Avatar
The job is complete. I got everything off and back on! I seem to feel a little more of a kick around 3K again. I'm pleased. I also have a nice exhaust note too! At idle, the Borla keeps my noise down. Not quite as loud as you lm6y. When I accelerate I sound similar to yours! (I saw and heard you leave Funfest)
Old 08-09-2000, 06:16 PM
i am a man of color i have the right to say that!!it is my thing...if you got offended then i am sorry...
Old 08-09-2000, 06:45 PM
Congratulations Hoff! Sounds like it was an epic battle for you. It must give you extra satisfaction that you did it yourself.
And no Shaun, I can't imagine anything you could say which would offend me - especially if it's a joke. I happen to have nothing up my own personal butt cheeks. BUT, seeing how some other may be offended, we should probably keep from making anybody feel alienated.
Old 08-09-2000, 06:51 PM
Banned
SHAUN.. do we have to have a little talk with your daddy....
Racial slurs are not where it's at...
This is a place to talk about cars...
Old 08-09-2000, 10:14 PM
Send a message via ICQ to Penz944
First stop fighting over stupid ****. 2nd that was not a racial slur. 3rd my friends always use it and we see it as that it doesn't have to do with colored people AT ALL. We just say it to be stupid and funny. Not to make colored people mad. You took it way to serious por2chboy!
Penz
1985.5 944
My 944 page
Old 08-10-2000, 08:52 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
You boys resolve this between each other, I'll be right outside...
I don't think you have the right to make offensive remarks at this board. If at the time you didn't think so, you MUST apologize, when somebody clearly tells you they were offended by it. Simple and clear.
If not, than you're NOT at the right place...
Ahmet
It's all the driver...
Old 08-10-2000, 10:01 PM
hoff944's Avatar
Would it be politcally correct if they would have said "Afro-Engineered"?
Old 08-10-2000, 11:03 PM
stray15's Avatar
Send a message via AIM to stray15
Different things may be racial slurs to different people. That is why you must respect people when they say that something was offensive.
"Afro-Engineered" You have to be kidding me. If you think that is any better, then you must not understand why the other thing wasn't appropriate. I'm not colored, and I'm not stupid. I can see exactly why something like that can be offensive. It has no place in todays world, let alone here at Pelican.
Tim
Old 08-11-2000, 02:55 AM
I really don't think this is something we should all dwell on here... BUT...
What if somebody says "Euro-Engineered." Is that acceptable? Surely it is. Why then would "Afro-Engineered" be so bad?
[This message has been edited by LtUSMC (edited 08-11-2000).]
Old 08-11-2000, 04:57 AM
