Current starter options for 944/85.1 (early) starter models
TLDR: I'd like to replace my starter. Does anyone still stock the large diameter starters?
After getting weaker and weaker and giving me a few push starts, the starter on my 1985.1 944NA has now finally given out. It is a large diameter Bosch starter with the markings 047 911 023A.
From what I've read, there have historically between two starter options that fit, an earlier large diameter starter and a later model smaller diameter starter. The later model smaller diameter starters will fit (95160410100), but its increased EMI may cause issues with speed/reference sensors and the replacement bracket to fix this is $125+. In 2012, people were enjoying a third option in Ideola starters, which seems to have gone out of business.
However, the current part number seems to return small diameter starters EG, https://www.*******.com/Porsche-parts/944/?year=1985&m=20&e=803&t=6&b=9&d=&v=12&keywords=starter
https://www.***************/pn/SR10X?
If I want to use the newer smaller diameter starter, the updated sender sleeve is $35 (https://parts.porschelivermore.com/oem-parts/porsche-sender-sleeve-94410132000) and it also needs a new bracket that is more expensive.
Does anyone still stock the larger diameter starters at an affordable price?
Old 09-02-2020, 10:10 PM
Did you look for a local rebuilder, maybe it just needs brushes and bearings?
Old 09-04-2020, 03:43 AM
How hard is it to swap the brush wiring on a VW Jetta starter so it spins the other way?
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 09-04-2020, 04:22 AM
You should be able to source the retrofit sensor bracket for cheap, to use the newer skinny-body starter,
I've had a ton of them over the years and don't think I sold them any more than $20 or so.
Old 09-04-2020, 07:10 AM
I have a NOS Bosch large diameter starter. It's new, not rebuilt; been on the shelf for many years. Yours for $100. michaelmount123 at geemail.
michaelmount
Motorsports Engine Development (Retired)
Old 09-10-2020, 06:38 AM
Have 944, will restore
mazdaverx7's Avatar
For comparison, I've had a smaller diameter starter on my 85.2 forb6 years and have had no issues of any kind with it. Its an aftermarket reman parts store unit.
85.2 944 Guards Red M456 5spd
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary
04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd
84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE
Old 09-12-2020, 05:47 AM
Tags
944 , early , replacement , starter
