Sensor???
On the dash in the center there are three sensors together. One is for the seat belt, one that says brake, and one that has a circle w/ three short dashes on each side. I can't figure out what the last one is for. I have an 84' 944. Need some help because it just lit up the other day.
Old 09-08-2000, 09:33 AM
that light is for the brake pad sensors. when you replace the brakes replace the sensors also. i believe you can only get the sensors from the dealer.
Old 09-08-2000, 04:58 PM
lm6y's Avatar
RAWXTC, you can get them from pelicanparts, Vertex, Performance, Tweeks..... O.K. you get the idea. They used to be a dealer only item, but now they are pretty easy to find. As far as the light coming on, get the pads changed pretty quick, the light means it's time NOW!
Old 09-10-2000, 06:56 PM
