951 hard into 2nd gear (no grinding)
Hi all it's my first post,
I'm having an odd issue with my 944 transmission. It won't go into 2nd unless I put it in 3rd beforehand, or push towards 1st. This would lead me to believe that it's the synchro...
HOWEVER, it never grinds (not once), and double clutching does not make it any easier put in gear.
I was curious if anyone has information or experience regarding this issue.
Also, I have spent hours using the search function and have not found any info that pertains to my specific situation.
Cheers,
Mikey
Old 12-30-2020, 12:06 PM
Dimi 944's Avatar
More than likely very worn synchro.
Sent from my Pixel 4a using Tapatalk
Dimi Paralanov
Flying Horse Motorsport
flyinghorsemotorsport@gmail.com
Old 12-30-2020, 12:35 PM
Yes, I suspect it may be, I just find it odd that double clutching has zero effect and the gear never grinds.
Old 12-30-2020, 03:06 PM
It could be a bent shift fork
Old 12-30-2020, 04:57 PM
Stupid question perhaps, but is the linkage ok, at the shifter and on side and top of the transaxle? Have you drained the oil and if yes, any metal chunks or shavings to be seen?
Best of luck ... and Welcome.
John
Old 12-30-2020, 05:18 PM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
My 951 makes noises in 4th and 5th, and its been that way for a good 5 years, syncros I reckon, it hasnt blown up yet, but I keep fresh gear oil in it..
Getting old sucks, bring back the good old days, this new stuff is for the birds..
Old 12-31-2020, 08:41 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Do you have a short shifter installed? If so, which one? A damaged stock shifter may cause shifting issues which can be solved by the installation of the short shifter from "Only944.com". If you buy one, get both the shifter and the linkage. It's a quality product.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 12-31-2020, 09:01 AM
