Question Black dust buildup after just 30 miles only on driver side rear wheel of ‘86 944
Scratching my head on why all of a sudden I have very fine black dust accumulating within just a few miles and only on the driver side rear wheel of my ‘86 944. Comes off easily with a dry rag but as soon as I put a few miles on it, it comes back and just on that wheel. Fronts and rear passenger side are clean as new. Car only has 37k miles, been well serviced, hasn’t seen rain in 20 years, and the only squeaks I hear occasionally are from the front, what’s happening? Thanks all
Old 05-25-2021, 06:26 PM
Did you change anything with the tires or brakes or suspension on the car?
Gone but not forgotten: 1971 914 First Car (SOLD) | 1972 914 rust bucket (SOLD) | 1986 944 Turbo (Murdered by a Chevy Truck on the freeway)
Current lineup: 1990 944 S2 Cabriolet - Long term project | 1971 914 - Long term project #2 | 1971 914 - Driver
Old 05-25-2021, 08:48 PM
No changes, just started happening. I only drive it once every month or so. It’s like a years worth of brake dust that accumulates in just a few miles.
Old 05-26-2021, 03:31 AM
Use a infrared thermogun to see if that brake is dragging. The rotor should be quite a bit hotter than the others if it is. Could be a sticking piston, rust causing a sticking pad, etc.
Good luck, George Beuselinck
Old 05-26-2021, 05:03 AM
sticking caliper will be pretty hot. the back of your hand in close proximity will let you know.
buy two calipers. been there.
an increase in fuel consumption is the first sign.
flush the brake fluid every two or the every few years even if you don't drive it much.
Old 05-27-2021, 04:19 AM
Toofah King Bad
Rasta Monsta's Avatar
Also handbrake shoes can drag.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 05-29-2021, 09:01 AM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
Black powder? Break dust....Check to see if a break is grabbing or dragging....Mechanical issue for sure..
Getting old sucks, bring back the good old days, this new stuff is for the birds..
Old 05-31-2021, 07:50 AM
Yes and remember to change your brake fluid every 2 years. Much cheaper and easier than doing it when you are replacing calipers or an ABS pump.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 05-31-2021, 09:26 AM
Tags
944 , brake , dust , rear axles , wheel
