replacing vacuum lines
hi ya. im replacing the vacuum lines in my 1896 turbo. im in the process of removing the intake manifold. what allis recommended while i have the intake off. i was going to send the injectors out to test and to be cleaned also. any other things i should do?
WoW. That is an old porsche. Where did you find it?
hah.... correction 1986!!
replace the icv and aos and brake booster hoses?
New AOS seals, new mounts on IAC, emissions delete (if allowed), venturi delete.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
Toofah King Bad
Reseal upper balance shaft.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
