weird 944 cold running problem
We have an early 84 944 in our shop that starts great and within 1-3 minutes of driving, begins to feel like you are driving thru mud. Lots of resistance with sluggish throttle response from idle thru 3200 rpm. After 3200 rpm, it runs okay- not perfect, but okay. Now 5 minutes into warm up, the symptoms disappear and the car runs perfect! Parts replaced so far: throttle switch, temp sensor for the injection, air flapper box. Fuel pressure okay, secondary okay, oxy sensor new, reference sensor new, coil new.
Any ideas?
Dave
Old 11-21-2000, 12:10 PM
Aux. Air Valve?
Old 11-21-2000, 12:35 PM
Obin Robinson's Avatar
aux air valve sounds like it.
obin
Old 11-21-2000, 12:41 PM
We will check and post the results- thank you
Old 11-21-2000, 01:53 PM
