Tsunamiboy's Avatar
Is short shift linkage worth the effort? 88 944 S
The car shifts well enough but have enjoyed short shift in other Porsches although in my 996 it created a problem shifting into reverse which was fine before installing short shift. I don't want to install one in my 944 and be diissapointed.
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 10-07-2022, 10:24 AM
You will be disappointed. Shorter throws imply increased force to make the throw.
A well adjusted and well lubricated 944 shifting assembly is just right.
Good luck, George Beuselinck
Old 10-07-2022, 12:52 PM
mistertate's Avatar
But it would be worth looking at your shifter with the boot off. The pin that acts on the shift rod takes a barrel shape, bringing slop. If it’s bad you can replace or fix it. I saw some one once drilled it out and replaced it with a bolt, tack-welded into place
Old 10-07-2022, 04:59 PM
The best answer is only944's shifter. For only $71, it fixes Porsche's design error which leads to wear out slop in the shifter. Porsche could have drilled one hole, threaded it and put in a Zerk fitting, then added it to the maintenance schedule. But they didn't.
Early '85
Old 10-07-2022, 06:11 PM
I say YES the short shifter is worth it, feels great.
Old 10-08-2022, 10:25 AM
J1NX3D's Avatar
I enjoyed mine
https://www.instagram.com/kiwi944s3/
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 10-08-2022, 03:02 PM
+1. this shifter is the sweet spot.
installed one and the shifting is much more precise and confident.
and it's pretty easy to install also
2002 Porsche 911 turbo
2007 Porsche Cayman S track car
1987 Porsche 924 Carrera GT tribute
2015 BMW X5
Old 10-08-2022, 07:18 PM
Toofah King Bad
Rasta Monsta's Avatar
With respect to George, the only944 unit is 100% awesome game changer. I love it.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 10-11-2022, 12:18 PM
Ernie944's Avatar
If a good quality ...short shifter kit ...is properly install ,it will give you hours of pleasurable driving ,had one on my ex 83 -944 & never regrett it never look back..
Caraquet,N.B. Canada.
Old 10-11-2022, 05:51 PM
