Send a message via ICQ to Azagal
Can I use unleaded on 931
I have heard that the engine should be made to use unleaded gas otherwise some parts (valves etc.) might get burned. So is 931 engine suited for unleaded gas?
Old 12-28-2000, 12:59 AM
What is a 931?
Old 12-28-2000, 04:58 AM
931=924 Turbo
Old 12-28-2000, 05:10 AM
I see, said the blind man as he picked up his hammer and saw.
Old 12-28-2000, 07:37 AM
Send a message via ICQ to porscheboi928s/c944t/n
sure why not.....i think it is the other way around........
Old 12-28-2000, 08:25 AM
Old 12-28-2000, 09:11 AM
u can use unleaded gas...
Old 12-28-2000, 09:29 AM
On my 1980 931, there is a sticker that says UNLEADED FUEL ONLY by the gas cap.
Nuff said.
Too bad mine won't run (yet).
Nick
Old 12-28-2000, 09:52 AM
Magnus_944's Avatar
If you live in the USA and your car has a cat the answer i easy: Use unleaded fuel, the engine has hard valve seats. But if you like me live in a country were cat didn't become standard until -89 the answer is not that easy.. Shell's swedish page (http://www.shell.com/content/54450/index.htm) says that the 924 Turbo can run on unleaded fuel (Blyfri 98) but BUT you must add lead replacesment (Blyersättningsmedel) to the gas. Check with your gas station, they might know...
/Magnus
Old 12-28-2000, 12:51 PM
lm6y's Avatar
If not, you can but a product called "Instead O' Lead" that will lubricate the valve guides, and seats. If it's a U.S. spec car you shouldn't have a problem with unleaded.
Old 12-28-2000, 03:00 PM
It is European version(model 1980, 170HP). What can happen if I drive it with A95H (unleaded)? The problem is that the A98 is too expencive here.
Old 12-30-2000, 01:32 PM
Azagal,
My wife's '82 has a connection on the driver's fenderwell that can be unplugged for lower octne gas. I heard that it retards the timing.
drew1
Old 01-02-2001, 05:55 PM
If the engine was made to run on leaded gas running unleaded will cause the valve seats to wear faster than normal. The only other problem would be the octane rating if it's not high enough. Next time you have a valve job done have hardend seats installed at least on the exaust valves.
Old 01-06-2001, 12:15 AM
Mikkel
Guest
Posts: n/a
Check out www.mittelmotor.de
Lots of info on Porsches and fuel types. Also an extensive list showing all Porsches and the fuel they need.
However it's in German.
Old 01-08-2001, 01:43 AM
