Unhappy Emergency!!!!! Please Help
I am pleading to anyone who may be able to help me.
I put a new clutch in the 83 944 today and broke the rear sonsor AND mounting bracket. I am embarased to even tell you how. But I will anyway.....The mounting bolt for the rear sensor was frozen into the bracket. I broke the top of the sensor off while trying to slide it out. I then broke the bracket trying to remove the mounting bolts for it. And everything went so good.
My request is does anyone have the rear sensor and or a mounting bracket? I would even buy both sensors if you have them. I need them by Saturday!!! I would even be happy if I could get them by Sunday. I will of coarse be happy to pay you a fair price and any shipping costs. Please let me know if you can help. This is my only means of transportation, and I need to work on Monday. Thank you in advance.
'83 944 N/A. Work in progress..More work than progress.
If you can't be good.....Be good at it!!!!
Old 07-03-2003, 05:50 PM
justin's Avatar
--bump--
Texas hosts the 928 Owner’s Club OCIC in 2009
www.928ocicdfw09.com
1980 928 5 speed and a few mods..........
928 OC member
PCA member
Old 07-04-2003, 01:28 AM
Thanks for the bump Justin.
Does any one have the part numbers for the sensors. I thought I saw that the two had the same number on a previos post. I can us the mounting bracket over as a temporary fix.
I will try Pelican and the other parts sources.
Thanks again.
Old 07-04-2003, 04:51 AM
you have a PM
Tom
Early '85 944
Old 07-04-2003, 06:15 AM
All is good again.
A VERY big thank you to Mr. Carsontc!!! He came through for me big time. He sent me his spare set of sensors AND a mounting bracket. Carson, I will make it right ASAP. I cannot thank you enough.
About the clutch.......Really not as bad of a job as I thought it would be. I used the instructions written by Clarks Garage. Very good. I will HIGHLY recomend that anybody replacing their clutch purchase a set of sensors and a mounting bracket. One of the sensors was frozen in the hole so hard I had to try and remove the mounting bracket. After not being able to remove the bracket I again tried to remove sensor by tapping up from underneath. Well that just broke the entire set up. Anyway like I said all is good. I even managed to do the clutch without removeing the exaughst. The entire project probably would have taken about 12 hrs. if I didn't have the sensor fiasco. Take your time and follow the instructions step - by - step.
Old 07-07-2003, 05:15 PM
