Shifter bolt 924s
A few thousand miles ago I took out the transmission to access the fuel tank in the car. Last week the shifting got sloppy suddenly and the pointed bolt that secures to the rod that goes forward to the lever in the car was loose. I swear I put loctite on it. Is this common to come loose? Maybe I forgot the loctite? Should I carry a spare pointed bolt?
Old 10-03-2023, 09:21 AM
IIRC, that bolt has a hole in it for safety wiring.
Old 10-03-2023, 09:55 AM
Thanks I’ll check it out
Old 10-03-2023, 07:37 PM
Northern Motorhead
wildcat077's Avatar
Yes , do safety wire that bolt, you don't want to be left stranded if it backs out or falls out !
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 10-04-2023, 03:51 PM
