Help
My passenger's side floorboard fills with water when it rains and I can't find the leak. I think it must be a window seal, but where? Can anybody help? bmac3566
Old 06-15-2003, 03:06 PM
Check under your battery tray.
rben
Old 06-15-2003, 05:09 PM
Yes. 944 battery trays tend to rust through from the acid if not cleaned periodically.
-Dave-
1969 911/3.0l SC
Old 06-15-2003, 05:57 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
also, if the drain plugs that empty water (from the windshield) are clogged, the water can't drain properly and ends up in the cabin. I had the pass. side water for awhile, and then I cleaned the drains and the problem was solved.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 06-15-2003, 06:47 PM
I appreciate your comment, but I have a question. I repaired a rust hole in the battery tray, and the drain holes for the windshield and sunroof, I extended with tubing, how did you unclog yours?
Old 06-16-2003, 04:29 AM
