I need HELP guys!
Can someone look at their O2 sensor & tell me were the wire leads to under the hood? PLEASE! It's an early 85....Thanks a million!
Shaun
Your pic didnt show up -- the reason I need to know is that Im missing the wire that runs between the sensor itself & the wiring harness, and am going to have to splice in something myself -- does it connect to a wire that looks like an ABS connection? Thanks |
Nope Shaun, it's a dead link.
Look on the fire wall next to the dme pick up connections (There should be two sets of male and female connectors coupled together in a metal brace near the rear of the cylinder head and above the flywheel). In close proximity is the O2 sensor hook up. I believe it is cylindrical in shape and black in color.
Erick |
Hey thanks Shaun -- thats what I thought it was....just wanted to make sure....I called a local dealer & they said they cant order just that wire...anyway, so if anyone has one they want to sell???
Shaun
How do you post pics? I took one because there are 2 empty wires at that location. One is fat & green (1 wire) other has two smaller wires (one male & one female)....is the green wire for an ABS option maybe???? ------------------ |
Which one is it?? ------------------ |
Lets try it again ------------------ |
Shaun,
Finally got it - which one is it ?? ------------------ |
nm... I messed up
[This message has been edited by Porsche 951 Fanatic (edited 02-07-2001).] |
Ah, there's a reason why you're not seeing that connector, Shaun. Early cars have a one-wire oxygen sensor, and late cars have a three-wire sensor. If you're looking for a three wire connector in an early car, you won't find one.
So its the GREEN wire then?
Hello??
Yes Weldin, it's the green wire. You will need the connector that plugs onto the one that is empty if you don't have one.
