Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
fan temperature switc
Hi,
Please help me with this:
when I turn off the engine the fans continue running not at the same speed (lower speed) for some mins until stops.
is it normal ? or I need to replace the temperature switch ?
Old 06-17-2003, 07:21 PM
If the fans actually stop running after several minutes then that is normal.
If they never stop (until the battery dies) then your temperature switch in the radiator is stuck in the "on" position.
-Dave-
1969 911/3.0l SC
Old 06-17-2003, 07:25 PM
Eduardo,
Being that it is summer time, a fan running after you cut off the switch is normal. I have heard of some with the low temp switches having dead batteries from this. The fan will run untill the radiator temp gets below it's cut off point.
drew1
Old 06-17-2003, 07:26 PM
thanks
then I`m ok
cheers !
Old 06-17-2003, 07:34 PM
Roger Hall's Avatar
On my 81 924 there is a ballast resistor behind the guage cluster on the firewall. It runs the fans at low speed untill the temp guage drops below the 1/2 mark then it shuts off. This is normal.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 06-17-2003, 07:37 PM
