Question Not getting power to the AC
Are there any particularly common areas to look for the fix. The relay is fine. the compressor will kick in if jumped, but not otherwise.
Old 07-12-2003, 05:13 PM
Scott R's Avatar
When you say "jumped" do you mean when you run 12V directly to the clutch? Or is it when you "jump" the pressure cut off switch?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-12-2003, 05:27 PM
rucool's Avatar
I had the same problem with my 951, if there is insuficient gas in the
system it will not activate the compressor. its easy for me to check as
I am an aircond tech. you may have to take it to a local aircond service
tech.as in my case it may only require a top up, but i converted it from r12 to an alternitave , works well.
Red 951 , chiped, very fast,showroom condition
89,951 sunday car/ 05 ,525i family car/
X5d every other day/ wellcraft eclipse21- 350 chev
Old 07-12-2003, 06:03 PM
