Porsche 924 turbo boost gauge
![]() ![]() Hi everyone, I'd like to retrofit a boost gauge into the original tachometer of my 924 Turbo. I don't have room in the center console because the climate control switch is located there. I also don't want to mount a separate gauge anywhere, so the tachometer is the only option. I don't want the gauge from the 924 GTS because it looks completely different. I've heard that the boost gauge from the Audi Urquattro would fit. There would be room for it at the top of the tachometer. Has anyone here done this conversion before, or what solutions have you found? Who makes special dial faces for these gauges? I'd really appreciate any tips. |
944s with A/C sacrificed the voltmeter for the A/C control switch. If you don't have A/C, you could do similar, sacrificeing the voltmeter for a small boost gauge. If you do have A/C, you could easily sacrifice the clock for a small boost gauge.
Early '85 |
Politically Incorrect
Maybe you could relocate the A/C switch?
Edek '87 924S '91 535i |
