Help can’t find this part.
I looked up both of these AC switches in the PET catalog and ordered them from pelican. The bottom one that pelican calls a pressure switch was correct but the upper green that pelican called a temp switch that wasn’t the correct switch. Mine screws into a schrader valve. I can’t find the part or part number anywhere.
Did you call Pelican Parts? The Porsche customer service people know so much about our cars and they will get online with you to find the correct part. Don’t guess. Call them.
I’ll try that thanks
In the Fires of Hell.....
PET shows the low pressure switch 959.613.137.00 as #15 for your car, plus there is a #16, which is either a Thermostat and/or another pressure switch, depending on VIN:
928.613.131.01 and/or 944.653.053.00 Look at the part on your car and see if you can read number on it.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
There isn’t a part number on the part. 928.613.131.01 is what I order and was wrong. I’ll take a look at the other part. Thanks.
Just check part 944.653.053.00 and pelican doesn’t have it. But 944 online has it. Thank you!
