5 digit odo's were common up through mid 1980's
Porsche changed them over on the 944 starting with series 2 (85.5+) 911\930 have always had the 6 digit odos AFJuvat |
OK. Will the 911/930 speedo fit in the early 944's so I can get six digits? Guess I might loose the GPM gauge.
would it matter considering that the mileage won't match anymore anyway?
Nope AFJuvat |
it would if you tried hard enough
or pried, for that matter :D
If the guts are the same then it could be a transplant. |
So, just checking. You'd like to have a working odo again and decided that you want a six digit instead of five? Personally, I'd stick with the original for, well, originality's sake. Unless it's your daily driver, you probably don't want to put too many miles on the car for it to be a concern anyway. Or am I misunderstanding what you want to do?
| All times are GMT -8. The time now is 07:37 PM. |
