bearone2's Avatar
Question cooling fans
are they rebuildable?
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 07-15-2003, 03:58 PM
TCMdocs944's Avatar
Flexfan makes a 9"(or maybe it's the 10) that is the same thickness, with motor, for less than $90. It seems to be much more efficient than the stock one.
As for the question...most electric motors are rebuildable but finding a shop(alternator shops are a good start) that will do it and do it for less than new is another question entirely.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 07-16-2003, 09:03 AM
bearone2's Avatar
I don't have the bad one out but wonder if it's a split case or a sealed unit.
If split I can probably do it myself unless parts for it are unique.
Old 07-16-2003, 09:47 AM
SoCal Driver's Avatar
The best "fix" for the fans on a 944 is to replace the front bearing with a sealed unit before they fail.
Water and dirt still gets into the front bearing besides being behind the hub on the fan and causes the bearing to bind and sieze up. When this happens the armature and comutator burns out.
I've just found one of my spares where I've replaced the bearing and have intentions of making a step by step with illustrations. It's not too hard really as you drill out four rivits that hold the front bearing cup in and swap out the bearings. I used some very small hardware (hut and bolt) to replace the rivits along with some thread locking goop.
So far the two fans I've done this too have lasted three to four times longer than the first one I replaced.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-16-2003, 10:30 AM
bearone2's Avatar
The cooling fan hasn't seize up yet, just major squealing.
Thanks, what I needed to hear.
Old 07-16-2003, 03:27 PM
bearone2's Avatar
If anyone has a cooling fan or two that haven't seized up, let me know what you want for them.
Old 07-16-2003, 03:41 PM
