seaboltman's Avatar
Figured i would ask this here : Violent shaking on acc.
My friend drives a '97 neon and when he acceclerates, his car shakes like crazy. He had the tranny looked at and supposedly its fine. Anyway anyone have any ideas? Thanks for any help you guys can give.
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 07-21-2003, 11:55 AM
Burn the fire.
Brando's Avatar
I think i've located the problem...
ITS A NEON.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 07-21-2003, 01:11 PM
BlueQuestTSi's Avatar
ITS A NEON.
LMFAO
Some of those Neons are using the Eclipse 2.0(4G63) motor. That motor does have balance shafts, so balance shaft belts maybe? Bad half shaft, bent spindle, bent wheel, tire fell off, faulty muffler bearing, you name it.
Jack
86 Red 951 - Turbo Twists, otherwise stock for now
83 Black 944 w/86 951 front end - still down and out, but coming back slowly.
02 Altima SE 3.5 - grocery go-getter
00 Yellow Ducati Monster 900i.e. 88 Chrysler Conquest TSi
Old 07-21-2003, 01:30 PM
TSNAPCRACKLEPOP's Avatar
ot ot ot ot ot ot ot ot , or am i in the wrong place, did i take a wrong turn in the desert?
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 07-21-2003, 01:57 PM
SoCal Driver's Avatar
The only time my car shakes is when I'm close to Mach 1.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-21-2003, 08:17 PM
Send a message via AIM to mart78
Busted motor mount?
74 Karmen Ghia (probally)
96 Gary Fisher Aluminum
Old 07-21-2003, 10:45 PM
MrPants's Avatar
(the engine that the neons shared with the eclipses isnt the 4g63, its a chrysler engine.)
-its probably a misfire
84 944 Non Alcoholic
Old 07-21-2003, 10:56 PM
Burn the fire.
Brando's Avatar
How many miles on the neon? two of the people at my work have neons. one just had an engine rebuilt for the same problem you have, the other is getting there... that, and their freaking parking break alarm goes off for no reason.
Old 07-22-2003, 10:08 AM
vott does ziss do?
ronin's Avatar
the anti-flutter spring in the articulation valve assembly is probably broken. It's easy to find, sits right behind the exhaust-gas intake suppressor. you have to remove the three screws attaching the occluded throughput housing though. manual says it's about a half-hour job
Old 07-22-2003, 11:05 AM
