Angry windshied wipers problem
1986 944 Turbo -The wipers work fine on the medium and high speeds. On the low speed, they either do not work at all or they shudder across the windshield in slow motion. The intermittent setting works only occationally - mostly not at all. What the deal?
Old 04-16-2001, 10:57 AM
Ehab's Avatar
Post
sounds like the relay, which controls all that stuff ... check on Ebay for a replacement.
E
Lock Stock '84 944 and two smokin' tires ...
Old 04-16-2001, 03:24 PM
Petie3rd
Mrmerlin's Avatar
Post
HI hello, hey remove the relay from the fuse box and take it apart clean with some fine grit sand paper the contacts inside then try it again.Stan
Old 04-17-2001, 05:57 AM
Post
If the above suggestions did not work, you probably have a bad switch in the steering column....My last 944 didn't work at all on high speed...I changed the switch, and it worked like a champ...Cus
Old 04-17-2001, 07:24 PM
