Any Ideas on what to do about this?
Heat has totally destroyed the plastic. One is obvious, the other is about the same under the electrical tape. I removed the tape and it crumbled in my hands. Don't want to replace the sensors just yet because they work fine. The wiring harness is in good shape so I dont want to solder them together. I have an idea but ... What would you do???
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Hmm, pics didn't insert right....Just click on them.
My plugs were broken too, but the sensors weren't working either. Those plugs might be fairly hard to locate. You might have to find a parts car to take the plugs off of to replace them.
'83 arctic silver 944 n/a Power steering? who needs it! |
You could use the filled "potting" epoxy used on electronics. Dark gray color. Have to make a mould around the plugs.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Epoxy's a good idea! BTW, isn't that your O2 sensor connector?
bertman 84 944 Original Owner 65 Plymouth Satellite 08 Mercedes-Benz E 350 Sport |
The epoxy works great.....
There is also a rubberized electrical tape liquid. Works nicely to give it a black rubber finish.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
quote
Epoxy's a good idea! BTW, isn't that your O2 sensor connector? __________________________________________________ _ Yeh, O2 sensors plastic is ate-up too but everything is intact. When you say epoxy, like any regular 2part? Just make a "plug"from it?
vott does ziss do?
should you not be able to get a replacement from the dealer, you could look for a similar plug with the same number of pins at a decent electronics store (i.e. not Ratshack) that would make for a clean (and probably safest) repair
Go down the junkyard and get a couple of sensors with the same plugs.
Cut the plugs off and solder the wires into your harness. All late (83-89) BMW 5 and 6 series use the same sensor, but with a longer wire.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
