repoman's Avatar
did I bend some valves; help please
While removing camshaft sprocket accidently moved cam counter-clock-wise appx 1" or 10 deg off of TDC.
Does anybody think I bent valves?
Would a post- assembly compression check verify if I did or didn't?
If bent, what indications would I see when hand-rotating engine and then starting.
One second of day-dreaming and pow....
'84 944 auto stock
Old 08-26-2003, 11:11 AM
MrPants's Avatar
im not sure but if you think timing is off dont start the engince cause then youll bend them for sure
84 944 Non Alcoholic
Old 08-26-2003, 11:46 AM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
Not Likely if you didn't turn it over. If you turned her over probably but, you would have heard it.
Re-align sprocket to mark. Flywheel to mark, and balance shafts to marks and tighten belts. Turn over by hand at the crank with plugs removed several times and check timing marks again. last piece for iinsurance purposes is to comp. check each cylinder.
Rick
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 08-26-2003, 12:53 PM
Roger Hall's Avatar
Rick
I agree with FLA944. If you used the starter then you probably bent some vavles. A compression test will probably show zero compression if the valves are bent.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 08-26-2003, 05:29 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
agreed
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 08-26-2003, 06:23 PM
repoman's Avatar
thanks guys, I feel better. All belts and sprockets were off with exception of cam sprocket. I was in process of removing it. Flywheel was locked but cam belt removed
Didn't read procedure throughly enough so was trying to remove by turning retaining collar with a 32mm socket on a 24" breaker bar. duh
Then I spaced off the fact that no cam belt in place; so no locking action on camshaft. double duh.
After it moved about 1" off of TDC mark, I woke up and rotated it back.
Don't recall any resistance or crunching/rending noises.
Gave it a twist but stopped as soon as I noticed movement. So hoping valvetrain is stronger than my arm!
I'll be sweating bullets until I reassemble & do comp check.
thanks again
'84 944 auto stock
Old 08-26-2003, 11:29 PM
