ldl ldl is offline
ldl's Avatar
10-40... no wait, 20-50... Crap. :|
Hey people....
I gots mes a question.....s (lol, i likeS the english)
lol.. ok, enough stupidness.
info
Car: 1985.0 944
Miles: Roughly 68,000 original
Question(s)
- What kind of oil should I use? (Using 10-40 right now, and it's leaking a little... Maybe from the bolt.)
- How often should it be changed? (I know it was previously posted, and I read said post, but does anyone have any further info?)
- Any recommended additives?
Well thanks for your time.
Drive safe all.
Bye.
85.0 944 Automatic
^ Bending my wallet over at every possible moment.
Old 10-01-2003, 05:31 PM
Some1else's Avatar
I recommend one Haynes manual for Porsche 944. Available at most parts stores!
I know because I have one sitting on my desk at work, and that is why I can’t actually answer your question! Perhaps someday I’ll actually memorize the entire thing!
83 944N/A Summer
88 4Runner Winter
Give me a “D” Give me a “Y” Give me a “S” “L” “E” “X” “I” “A”!!
What do you get? Dilex.. Dislax.. Dylsia… AHH F**K IT!!!!!!
Old 10-01-2003, 05:44 PM
ldl ldl is offline
ldl's Avatar
I've read it... BUT I am asking for users experience.
As in what they recommend, what's they've used, and what works the best.
Thanks for your time.
85.0 944 Automatic
Old 10-01-2003, 07:33 PM
Scott R's Avatar
Depends on what your doing, at 85 deg, and on the track 10W 30 Mobile #1 is too thin. So then you need 20W/50 so it lubes better. Winter time daily driver use the 10W 30 or 40, the syns tend to run a bit thinner when they are hot,
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-01-2003, 08:08 PM
adrian jaye's Avatar
hey ldl,
ok a cuple of things
generally you can not go wrong with what is recommended by either Porsche (manual/drivers manual/haynes etc) or your dealer.
Deviation is at owners own risk !
However saying that, when the 44 was made oil technology was a lot different as is the service intervals.
so a few points
1: oil changes are somewhat dependant on use of car, racing, street use, garage queen
2: You can NEVER over do the ammount of oil changes you do, as long as it is a MINIMUM of 12000 miles/yearly. I know some ppl recommened every 3000miles, I do mine every 6k.
3: Oil is not only a lubricant it contains bits a pieces of metal etc. from use, so getting rid of this crap, helps to prevent wear and tear.
4: There is also a proper procedure to do an Oil change, which a "main dealer" would not confirm, but engineers in the know swear by. (Posted on TiPEC and NotJustPorsche Boards)
5: oil types: I think when "16" gets a service its done with Mobil1 (whatever that is) recently I have used Shell Helix+ which is a slighly viscous oil.
6: Your drivers manual will give you a list of oil specs for your car and will then say "contact your dealer for recommendations) helix+ and mobil1 comes under thoes specs.
I think either NotJustPorsche/Tipec or my own site has a tech FAQ with recommended oil types.
Hope this helps
Adrian
(BTW your right, it helps to get input from real world members as opposed to documentation, but not always)
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 10-02-2003, 01:03 AM
rbt944's Avatar
I was first using 20-50. Then I changed to 10-40 but my oil pressure was too low and I panicked. So I changed back to 20-50. I'm at about 144,000 miles right now but I have only put somewhere in the neighborhood of 24,000 miles on it. I usually change my oil around 4,000 miles. I use Castrol. I've used Exxon once.
-Gus.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 10-02-2003, 01:36 AM
ldl ldl is offline
ldl's Avatar
Well thanks guys..
Much help.
Stay safe.
Bye.
85.0 944 Automatic
Old 10-02-2003, 07:47 AM
20-50 here. It never gets cold enough in California to require a lower viscosity oil. Unless you plan on doing most of your driving in cooler weather (early morning/late night) or plan on driving short distances, I'd use 20-50. Likewise, if you're doing most of your driving in cooler weather or on short distances (it will take the oil longer to heat up and really do its job in either case), go for the 10-40. I personally use Castrol (stuff in the green bottle) and I find the synthetic blends are too thin (a leak started where it wasn't before ). Change it at least every 3k miles! Your engine will last longer with less wear and tear.
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 10-02-2003, 08:37 AM
ldl ldl is offline
ldl's Avatar
All right... good deal swimmingly..
My fellow LA county resident.
lol.
Bye.
85.0 944 Automatic
Old 10-02-2003, 01:15 PM
Non Compos Mentis
Kendall GT-1 20-50. The car sees the track fairly often, and is driven pretty hard.
My hot-rodded 911 autocrosser uses the same.
Old 10-02-2003, 02:06 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
I run 15-50 mobil one synthetic...otherwise if I use dino juice its 20-50....for some reason these cars better witha thicker oil....someone should try truck oil..
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 10-02-2003, 05:52 PM
Z-man's Avatar
I also run Mobil 1 15W-50 synth. But I do track my car, hence the need for a little thicker oil.
-Z.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 10-03-2003, 07:32 AM
