Originally posted by tclyder
Any other bright ideas?
Hmm, sew a long strand of leather strip around base of boot. Then tie it down to a tight knot around the the funnel base.
Old 10-28-2003, 07:48 AM
Wow, that's a new one on me - my inner shift boots have always been incredibly tight on that metal ring, I've had to warm them up to stretch them onto the metal lip!
Sam
Old 10-28-2003, 08:28 AM
Send a message via AIM to tclyder
Do you guys think there is the possibility the PO switch this boot at some time in the past and it is from some other model Porsche?
I believe the 944's used the same boot from '83 through 91.
Tom
Tom
Our Car is a early 1985 944 with a manual trans
Old 10-28-2003, 10:52 AM
A new one is about $20, if you'd like to try that - I'd measure mine and let you know diameter, but I'm nowhere near the car. I suspect replacing it'll solve your problem.
Sam
Old 10-28-2003, 02:17 PM
Do you mean you can get that rubber boot from a porsche dealer for $20? or Ebay?
Tom
Tom
Old 10-31-2003, 05:06 AM
I've gotten 3 online, 2 through eBay - that's the easiest option for me.
Sam
Old 10-31-2003, 09:04 AM
I bought a new one on ebay - hope it comes in today so i finally can get it all back together - hope this one will fit correctly
Tom
Tom
Old 11-04-2003, 10:32 AM
Smile
Yeah!
Installed the new rubber boot and it fits perfectly - no doubt the PO had the wrong one installed (thats another reason why the leather boot never fit correctly and always was coming off!
It had to be the wrong boot becauser there is no way iy would have stretched so much at the base.
TOm
Tom
Old 11-10-2003, 05:21 AM
That's what I thought also - glad you solved your issue.
Sam
Old 11-10-2003, 09:22 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
There is a sound absorbing collar that is missing. It goes over the metal ring I think. 477 711 239....Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 11-10-2003, 10:35 AM
Because I probably didn't know any better I used a tie wrap which graps the rubber boot and it is under that metal ring so it is snuggly held in place and will not wiggle off unless the tie wrap would be cut off.
Tom
Tom
Old 11-10-2003, 01:37 PM
I am Almost done
Here is a picture as to where I am At so far.
Tom
Old 11-11-2003, 01:03 PM
