Okay, nothing is really going wrong with my car right now, It's time I worry myself with something else potentially going out.
About...2 months ago my car seemed to get louder. I think it's coming from the rear, sounds almost like the engine got louder...only it's in the rear. Pushing the clutch in doesn't help. I can only hear it above 30 mph, it also stops when I turn right, and I'm pretty sure it does the same turning left. Sort of a rumbling noise...I also need to replace my clutch, I've got the shudders and some rare slipping.
'83 arctic silver 944 n/a Power steering? who needs it! |
Feelin' Solexy
This might sound stupid, but I'm a big fan of Occam's razor.....have you taken a good look at your exhaust? I've found they like to fail where the exhaust is welded to the muffler. After that, when was the last time you looked at your CVs and wheel bearings?
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
Your nuts are loose!
Well, the nuts on the rear stub axles. Or one of your roller bearings is dry and has spun it's inner race on the stub axle. If you haven't repacked them (the rear bearings) in 30,000 best to open them up and talk a hard look. Be prepared to replace the stub axles as well as the bearings and seals.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
