strange spark plug wire situation
i bought some new spark plug wires and i hooked them up. and i checked several times to make sure they were hooked up in the right firing order, and they were. Well....the car wouldn't start at all. So i thought the wires might have been bad that she sold me, so i plugged the old ones back up, and the car still won't start. The firing order is right. but atleast 2 cylinders would fire up with the old wires. Anybody got a clue. Its really stormy here right now, could the weather affect it. This is the car that has been stored for 2 1/2 years and i recently got it started by replacing the fuel pump!
1986 944 non-turbo
Old 10-28-2003, 02:22 PM
Send a message via Yahoo to clinton
Sounds like two injectors are not working. What two cylinders are working ?
Visit my site www.orderdairy.com/Porsche/
Old 10-28-2003, 02:45 PM
the first and the fourth. But the car started fine with the old plug wires the other day. and today it won't start with the old ones, or the new ones. The car is parked under a garage, but its really stormy outside right now.
1986 944 non-turbo
Old 10-28-2003, 02:50 PM
first and fourth don't work...the 2nd and 3rd DO work!
1986 944 non-turbo
I would cheak the wires to the injectors first,I think the 1 @ 4 injector fire at the same time as do the 2 @ 3 so it sounds like you have a injector wire problem . They both could be pluged up but not likely the same time .
Old 10-28-2003, 02:58 PM
but even cylinders 2 & 3 would fire the other day, enough to start the engine!
1986 944 non-turbo
Old 10-28-2003, 03:06 PM
I would look at the wires to the first and forth then. Are you sure the cap and rotor is ok. Are you getting spark to all cylinders ? What do the plugs look like?
Old 10-28-2003, 03:12 PM
MrPants's Avatar
id check the cap and rotor. is there spark from the main wire to the distributor?
84 944 Non Alcoholic
Old 10-28-2003, 03:23 PM
everything is firing ok...i disconnected wires from cap and the points are firing ok...i just bought a new fuel pump...and i depressurized the fuel line, jumped 87b and 30, and the pump won't cut on....the pump is a week old and its already gone out again! anybody got any idea what may have caused it to go out like that??
1986 944 non-turbo
Old 10-28-2003, 04:57 PM
What kind of distributor are we talking about with points?
drew1
drew1
wife has 924 turbo
Old 10-28-2003, 05:58 PM
Feelin' Solexy
Tishabet's Avatar
Ahem.
http://forums.pelicanparts.com/showthread.php?threadid=132811
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 10-28-2003, 06:12 PM
the points on the distributor cap that the spark plug wires connect to...i disconnected the spark plug wire from the cap and the electricity was arking off of it pretty good. There has got to be a short not allowing enough energy to go through, or either too much energy and is burning up the fuel pump! Or maybe i got a bad pump. its got a lifetime warranty so i'm sending it back. Could it be maybe debris in the gas tank formed or something, the gas is 2 1/2 years old in the car. And it doesn't get filtered before it goes into the pump(go figure). Why would you put a fuel pump before a filter, wouldn't that cause more of a risk of fuel pump failure?
1986 944 non-turbo
Old 10-28-2003, 07:31 PM
MrPants's Avatar
can you hear the fuel pump running if you go put your ear by it?
Old 10-28-2003, 08:35 PM
SoCal Driver's Avatar
I've found the problem!
"the gas is 2 1/2 years old in the car"
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-28-2003, 09:56 PM
Yep, SoCal is right. Gas that old can be nasty. You need to drain or siphon as much of the old gas out as you can. Refill with nice new fresh gas. I'd probably change the fuel filter too. See what happens then but you may get to run some "cleaner" through if you've got gunked up fuel lines and associated parts.
Old 10-28-2003, 11:08 PM
the filter is new...and so was the fuel pump. Do you think the DME may have played a part in it to? If the DME is not sending enough current, it could burn it up, should i replace it, or do you think its just the bad gas?
1986 944 non-turbo
Old 10-29-2003, 04:29 AM
Kirby2's Avatar
Now, not later, swap out the injectors for balanced and clean ones. ($125 ) Drain the tank (don't try to resurect old gas with stabilizers). Refil with a good cleaner - mine likes techroline.
The gunk in old gas seems to be able to pass through the best new filter and create havoc. I fought this for a year after a stop at an BAD gas station.
03 Silver PT Turbo - Ours
86 White 951 - His
86 White 944 Manual - Hers
98 C-4 Sons
86 Gold 944 Auto - Sons
84 Maroon 944 Auto - salvaged
78 Yellow 924 - found a new home
Old 10-29-2003, 07:27 AM
The DME does not send out current to the injectors or the fuel pump. It grounds the injector circuits and the second coil in the DME relay.
If there is insufficient power to the injectors because of worn contacts in the DME relay then the DME can only ground out what is there.
The DME takes the second coil in the DME/fuel pump relay to ground. The current going to the fuel pump is then from the battery through a fuse.
You can age whiskey. You can age wine. You CAN NOT age gasoline.
If you truly are burning up fuel pumps it's because you didn't drain and clean out the fuel tank.
Old 10-29-2003, 07:45 AM
1) Use a spare battery or battery charge to put power directly to the pump to see if it will turn on. You may have a faulty wire providing power to the pump.
2) Clean the speed and reference sensors .
Stay Posted - more to come.
Old 10-29-2003, 09:46 AM
Scrambled,
Theres's nothing likea no crank early 944, no codes, etc. I'm going to suggest putting a guage on the fuel rail & see if the pump builds up pressure when you jumper 30 & 87 on the relay socket. There is a strainer at the tank outlet to the pump. After you drain the tank, clean the crud out of the strainer. Maybe the new pump will work then. Most places don't have warranty on electric parts. Hope you don't need new injectors, try some Techtron in new gas.
Good luck & keep trying. You'll be awfully proud when you get her running.
drew1
drew1
wife has 924 turbo
Old 10-29-2003, 03:30 PM
