Brandon85-944's Avatar
Send a message via ICQ to Brandon85-944 Send a message via AIM to Brandon85-944
Post In need of specific parts.
Hey all.... Info: early 85 944 n/a 110,000 miles...
If anybody has the following parts or off the same car or anything compatible please respond..
1) I need the male end on the car 02 sensor harness that the female end of the 02 sensor wire attaches to. I believe the male end runs back into the DME. I just need the male part not the whole wire running back to the DME, so it would require some cuting so I could splice it back to mine and hook up my 02 sensor.
2)This on is hard to describe....(need a pic) there are two front fender flairs on the cars immediately before the wheel well that both house side marker lights. ONLY on the driver side , inside the wheel well directly in front of the tire there is, what appears to be plastic, piece that attaches to the driver side fender with a bolt, with keeps the fender pulled towards the front of the car. This piece is easily removable with about 5 other , like 9mm , bolts.
If anybody has any info on where I could obtain these I'd apprecieate it....
Brandon85-944
Old 07-17-2001, 06:26 AM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Post
hahaha I need a flare support too..good luck-chris e85 944
Old 07-17-2001, 07:29 AM
Talking
Brandon,
I was looking for the same thing for my O2 sensor. I believe it is a resistor. It is on the firewall, about in the middle of the car, right ? What happened to it ? Did it just crumble apart when you went to unplug the O2 sensor ? That is what happened to me. I was able to set one from www.20thstreetauto.com for something like $25. I had to describe it to them (things like legnth, diameter, color, etc.) They sent me the right part the first time. All I had to do was splice it in with a solderless butt connector and cover that with some shrink tube. Hope this helps. If you want, you can e-mail me and then I can give you my order number for reference when you order it.
[This message has been edited by Cake944 (edited 07-17-2001).]
Old 07-17-2001, 02:25 PM
