This is pretty much a MUST FIX SOON thing. My fuel guage registers empty and it is filled full of gas. Where should I start looking on trying to fix this part. Any help will be greatly appreciated. Thanks!
1986 944 non-turbo |
it's most likely your fuel sending unit located inside the gas tank. i believe it is pretty easy for you to check, there are plenty of posts on the subject...do a search and you will get step-by-step instructions. i had my mechanic do mine and it wasn't cheap, but if you do it yourself it's not so bad.
87na guards red(mine) 98 suburban(mine) 04 4Runner(wife's) |
Feelin' Solexy
What did you end up using to clean up the tank? Maybe the same thing that was gumming up your tank is gumming up you sender. Take the sender out and put a multimeter to it.
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
where exactly can the sender be located/removed from?
'82 928S ![]() '85.0 944 Not Awesome - Being Parted Out
In the rear hatch under the carpet?
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
What would Darth Vader do
Yes
1983 944 (2002 to now) 3-924's (Sold) 1967-912 (Traded) NEVER put a used water pump in your car... |
Read somewhere it was pretty simple...............do search.
thanks guys that worked...i took out the sender and sprayed it down, inside and out, with carborator cleaner. The guage works like a charm...i do think the same stuff that gummed up the strainer was gumming up the sender! thanks again for the help!
Feelin' Solexy
http://clarks-garage.com/shop-manual/elect-13.htm
This link shows the system in detail. Just FYI
