Major leak
Please help
I have developed some sort of MAJOR leak that drains directly into the rear passenger floorboard. I does not come from any visable leak. Thanks for any advice |
Let's go shooting.
Sounds like you're going through the same problem I am currently suffering (see soggy carpets about a page back). Assuming that it's not attributable to the battery box leak the 944 is oft afflicted by...
Sounds like a sunroof leak (which is what I've had) Either the little drain holes are blocked or the internal pipes have come adrift. If it's not either then it could be a weeping sunroof seal or, as mine is, water creeping under the plastic trim in the roof hatch. Often the leak cannot be seen because it sneaks past the trim and then drains down the back of the speaker panel, down past the seat and onto the floor near the seat belt fastening. If it's the latter it takes a lot of effort to dry all that foam and sound deadener out. Could also be where someone has pushed the sunroof button by accident after the ignition switch has been turned off - rendering the sunroof removeable and less water tight.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." |
Certified Rennwerker
Yes....drain tubes are blocked coming from the sunroof. Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Could also be the door seal on that side or even the seal around the quarter window.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Despite what I fervently believed, mine turned out to be the battery box. PO have "fixed" it with a license plate and fiberglass. The leak went along the inside pass rail straight to the back seat pass foot.
Finally pulled all the old repair out and POR-15'd it. Mysterious leak solved. I will post the pics soon of that job.
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
