-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Intake boot in pieces (http://forums.pelicanparts.com/showthread.php?t=138809)
Don 944 LA 12-08-2003 12:01 PM
Well I got some intake / throttle body cleaner spray.
So, yesterday I figured just take off the boot and spray some in the throttle body.
Easier said than done. That boot has all kind of clamped hoses etc... well, in muscling it off, the fawkin thing fell apart.. DOH !!!!!
Got a new one on the way overnight.
I tried to run it with everything off.... talk about rough pinging... I just hope I didn't mess anything up.
Does anyone have any pointers etc in the intake area that I should address while I'm there ????
Don
TCMdocs944 12-08-2003 12:42 PM
Yes.
If that hose was that deteriorated you will have a whole slew of vacuum hoses that need to be replaced as well. This car relies heavily on the vacuum system.
Leaks can cause all sorts of disturbing symptoms. If you don't want to replace some of the hoses at least make sure they are tight on the connector. If not...zip tie it for now and replace later.
Welcome to the board.
Don 944 LA 12-08-2003 01:17 PM
Thanks, Willl check as well.
Are most of the hoses a standard size ( I.D. / O.D. ) ???
If so, maybe I should just get a slew of hose and replace ????
SoCal Driver 12-08-2003 03:01 PM
Re: Intake boot in pieces
Don
DOH !!!!!
Don
profssr2017 12-09-2003 08:39 AM
I know Don 944 LA wrote about something - I just can't take my eyes off of his Avatar long enough to read it!
MrPants 12-09-2003 12:15 PM
you ran your 944 without the air cleaner????
Don 944 LA 12-09-2003 12:28 PM
Yeah, It was ( Shall we say ) " Real Rough ".
Well, Just got in the new OEM Boot, gonna put it on now.
I checked all the lines and they seem fine.
I Duct taped the 1/2 inch gap in the boot yesterday and ran it. Seems better with the gunk off the throttle body, But didn't want to risk loosing the seal around the tape so I didn't stress it too hard.
Thanks for all the input guys
Don
1984/85 944na
Gold exterior / Black interior
Los Angeles / San Diego
Lookin for ideas etc...
http://www.carquip.com/parts/graphix/944.jpg
ae1969 12-09-2003 12:38 PM
uhmmm you realize that the AFM must be connected to the intake with no leaks.... hence the rough running.
It definitely should run better with out that HUGE leak in the intake..... :) I am surprised it even ran. LOLOL
TCMdocs944 12-09-2003 01:59 PM
That............
................................Avatar..........
.................................................. .......is..........
Coolllllllll..........................
(cant...............stop.................looking)
