well i finally got my timing belt done, i get to pick the car up tomorrow. the down side is that i found out that my a/c compressor is bad and also that 2 powersteering lines the pump and rack need to be replaced... that sucks... oh well.
Special Edition 924S 1988 <- SOLD! Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker. |
How much did you pay for your T-Belt job?
It isn't to hard to replace the powersteering lines and you can rebuild the pump and rack yourself if you have a jack, jackstands, some wrenches, and patience. Goodluck
The crashes people remember, but drivers remember the near misses. – Mario Andretti 1991 944S2 Rally #951 Rally-America.com |
I can see having to buy a rebuilt pump but you can do the hoses and rebuild the rack.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Hmm, buying a rebuilt pump? When I rebuilt my rack, I ordered a pump rebuild kit, because I knew it was going to go next. When I was asking about the difficulty, I was told any idiot can rebuild a pump, but it takes dedication and lots of time to rebuild a rack. He was right about the rack, took me well over a full weekend of cleaning things! However I have not done the pump yet, looking at the kit, I think it would take about 2 hours, so you're probably better off rebuilding it yourself, for about 20-30 bucks, much cheaper =), and if you're doing the pump, you might as well do the hoses and rack yourself.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
I'm thinking of the bushings/bearings. If the shaft is worn out you can't rebuild the pump. Not much to wear out in the steering rack.
rebuilding the parts myself would be great.... but its my daily driver. ill prolly pick up a little putter car to drive first before i try and tackle anything like that.
rebuilding the parts myself would be great.... but its my daily driver. ill prolly pick up a little putter car to drive first before i try and tackle anything like that. oh and im picking the car up today, cost about 650 for parts and labor plus tax. also i was having them remove that damn oil drain plug i snapped 2 sockets on. once i get it back ill tell you how the service from vertex is. theyve been pretty good on all the parts ive bought from them so far.
