seaboltman's Avatar
I was changing the coolant and...
Found out the PO had broken the Drain Plug. Anyway, so im screwing the Drain plug back in and... It goes into the radiator. Yay! just what i needed, so now i have a few Questions.
1) should i get the piece out of the radiator,
2) Will any local shop have a drain plug for me
I have a picture of the coolant, think some oil might have gotten in. Ill have to post it later. Till then thanks
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 12-16-2003, 01:34 PM
Plug is not very expensive even at at P dealer. I replaced mine several years ago and had to buy it from the dealer. I would tend to leave it where it lies. It probably won't get by the thermostat. If it jams in your thermostat, you'll know it and you can go after it then.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 12-16-2003, 01:43 PM
ae1969's Avatar
Send a message via ICQ to ae1969
.... I hate those plastic drain plugs.... in my rookie days I tried taking it out....messed up the plug....wrecked the radiator plastic...aughhhh
To make a long story short. New radiator.
SO follow Lawrences advice.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 12-16-2003, 02:28 PM
88_944's Avatar
The first time I had to drain my radiator I've tryed to take the plug out but it was not moving so I knew since it was plastic it will break if I go any more. So I just removed the lower radiator hose and bam, It was a better idea to do. .
My Black 944
My Gaming Forums. Xbox360gen.com
Old 12-16-2003, 03:16 PM
SoCal Driver's Avatar
The shaft of the plug has an o-ring. It's this o-ring that does the sealing not how tight the plastic plug is.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-16-2003, 04:12 PM
Burn the fire.
Brando's Avatar
anyone with access to a lathe should make a replacement drain plug out of aluminum or steel, methinks.
Just a thought for those with access to an 'extended' shop.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 12-16-2003, 11:38 PM
