headlight motor and linkage
Hey Porsche, I know you can hear me. Why one motor and some big noisy heavy lingage going all the way across to the other headlight? Why not two much smaller motors, one mounted on each side- way quieter, less space. Next time, OK????
1994 BMW 525i dark blue 1967 Saab "96", Red, Needs Help |
914 did this. The 944 is actually simpler and less prone to failure, believe it or not, although I wish they had permanently mounted lights and had trashed the rotating idea altogether....
Bob S. former owner of a 1984 silver 944 |
I like my flippy lights.
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
I once had a earlier model Sunbird with flippy lights. More like flippy shields. It had a 2 motor setup. The gearing (dried up) and when you turned the headlights on or off they would produce a screeching sound that is comparable to a shreiking banshee conjured up in your worst of nightmares.
Applaude what Porsche has givin' you. It can always be worse!
"We are the music makers and we are the dreamers of the dreams" -Willy Wonka |
Ornery Bastard
My old Accord had a two motor setup for its retracting headlights and it worked flawlessly for 217,000 miles (I can't say for sure after that since I sold the car at 217,000 miles). I really don't think that either system is better than the other, the 914, it must be remembered, is a very old car and given the 914's fairly notorious electrical system it's not surprising that it had problems with the headlights (mine hasn't, so far). Sure a one-motor system has the weight of the linkage, but it also lacks the weight of a second motor. The only drawback I see in the one motor system is a lack of redundancy. If one motor fails, then you have no headlights. In a two motor system, if one motor fails at least you still have one headlight. But the chances of a motor failure are so small that it really doesn't matter in practical application. Usually the failure is in a relay or the wiring which would disable a two-motor system as well as a one-motor system. Aaron
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
Don't think Porsche did too bad when you realize that the 924 was one of the first semi-production cars to have retracting headlights. Actually the third Porsche model as the 914 and 928 were before it.
Think about how many times you turn the headlights on-off. Pretty good MTBF's.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
With the 924/44 you can still have headlights even with a motor failure, using the manual knob.
Ornery Bastard
Aaron
Aye... let me rephrase.
Thank god for four letter carnal verbs!!
