Send a message via ICQ to porscheboi928s/c944t/n
Post N/A cam on a turbo 944
yup!!...in my cars case it did work...a little sluggish in the bottom but once the boost comes it hits hard....
i had it installed(n/a cam) in my car for quite awhile but with other upgrades i did on the car i can't really tell(post) not until i installed the original turbo cam back yesterday....tried the car this morning and i didn't feel it like the way it was with the N/A cam...so i am going to put it back now!!...yup!! right now!! just waiting for the engine to cool down....and it sounds a little rough when at idle....
sorry no dyno sheet to prove...but from the way i felt it..there was a change...
also comparing the boost with and without the N/a cam...the n/a gained 2 more psi.just by replacing it and nothing else done......
Old 09-05-2001, 09:29 AM
Post
Oppps!1 before i get flamed on the boost....reason i said it is bec.. my car's wastegate is fully closed(locked)...reason being is bec. the cross over that i put is big and won't build up more boost(less velocity)...so it regulates at 16 psi.for now....so with the n/a i achieved 16 but with the turbocam it is only at 14...
Old 09-05-2001, 09:42 AM
Post
thats odd, I have a turbo cam in my NA and I have no performance difference. The mech told me the cam's were exactly the same. Anybody have access to the both the NA and the turbo cam specs?
[This message has been edited by javier (edited 09-05-2001).]
Old 09-05-2001, 10:09 AM
951carter's Avatar
Post
my understanding is that the early n/a cam is the same as the turbo but the late n/a cam is different. i have not verified this personally. do you know what year n/a cam you had in the car?
Old 09-05-2001, 04:58 PM
Post
Heard somewhere that exhaust lift & duration is different.
drew1
Old 09-05-2001, 08:26 PM
