Banned
Send a message via ICQ to Craig944
Post This Steering wheel should fit surely...?
http://cgi.ebay.com/ebaymotors/aw-cgi/ebayISAPI.dll?ViewItem&item=595393297&r=0&t=0
TIA
Old 09-16-2001, 08:12 AM
AFJuvat's Avatar
It should (I was thinking about bidding on it myself)
I think the steering wheel mounting hardware should be pretty much the same.
AFJuvat
Old 09-16-2001, 10:01 AM
MAS MAS is offline
Post
It looks like the steering wheel on my 87 924S
(the 924S did come with the 3-spoke option... although the Porsche crest on mine is just embossed)
-MAS
Old 09-16-2001, 10:54 AM
Post
Hi Craig,
Caution! If it is a 911 wheel, then it will not fit straight to a 944. The splines are not the same on the hub, at least not between my '88 951 and my '76 Carrera.
You can easily remedy to that by swapping the hubs. It takes 4 rivets to drill out, and 4 M6 bolts with nylock nuts. I did that many times.
GeorgeK
Old 09-16-2001, 12:45 PM
stray15's Avatar
Send a message via AIM to stray15
Post
It will fit
Old 09-16-2001, 12:48 PM
Banned
Post
So the splines ARE the same?
Old 09-16-2001, 02:35 PM
stray15's Avatar
Post
That is the same wheel I have.
Old 09-16-2001, 04:35 PM
951carter's Avatar
Post
George is correct, it will not fit. it looks the same as the early 944 wheel but it is not. Craig, the 944 3 spoke would be a downgrade from what you have. it will sit lower and hit your knees. you can buy a new leather wrap for your wheel for $40-50. or you can send it away and have them do it for $150. I suggest drivng a 944 with the 3 spoke before you consider buying one.
Old 09-16-2001, 04:59 PM
stray15's Avatar
Post
So there are 2 different 3 spoke wheels? Which were used on which cars?
Old 09-16-2001, 05:27 PM
Post
The wheel itself may be the same, but the hub is different. There actually were 2 series (and 3 versions) of the 3 spoke wheel, but the limiting factor here is the hub.
GeorgeK
Old 09-16-2001, 09:00 PM
tifosiman's Avatar
Post
It will not fit. My friend has a 911SC and the spline is different, I got a good look at it this weekend when we were putting a Momo wheel in his. I also think that the old 911SC wheel would be a downgrade. They are very "dated" looking, more-so when you see one in person.
Tifosiman
Old 09-17-2001, 04:48 AM
Send a message via ICQ to diannone
Post
try it , you might like it. but then again it might not fit.? personally i think it looks old and out dated. a new wheel is much much better. if your tring to impress with the looks? check out the roll bar on ebay. just a thought?
Old 09-17-2001, 06:11 AM
