AFJuvat's Avatar
Running kind of funky
Well, after dropping about $2100 into maintenance on my 85.5NA, I've had it out of the shop for a week and I have to say that the "pep" just isn't there at low end (below 3500) anymore. from 3500 - 4000 I get the "push you back in your seat" feeling.
Maintenance performed:
Clutch job (the works)
New speed sensors
front sealt,
Water Pump
belts
Factory Power Steering upgrade kit
Shop checked the o2 sensor and said it was fine - also, had new wires put on a few months back
I am contimplating rebuilding/cleaning my injectors tomorrow
Any other input would be helpful
AFJuvat
Old 10-19-2001, 09:19 PM
Smile
Sounds like a timing problem! Check to make sure the TDC mark on the cam (viewed through the hole in the cam gear cover) and the OT mark on the flywheel (viewed through the little hole between the engine and the firewall) line up.
Mark
'86 944NA
Old 10-21-2001, 07:48 PM
AFJuvat's Avatar
Post
Thanks, will have them check that when I get the belts retensioned in a week
AFJuvat
Old 10-22-2001, 01:28 PM
