Running kind of funky
Well, after dropping about $2100 into maintenance on my 85.5NA, I've had it out of the shop for a week and I have to say that the "pep" just isn't there at low end (below 3500) anymore. from 3500 - 4000 I get the "push you back in your seat" feeling.
Maintenance performed: Clutch job (the works) New speed sensors front sealt, Water Pump belts Factory Power Steering upgrade kit Shop checked the o2 sensor and said it was fine - also, had new wires put on a few months back I am contimplating rebuilding/cleaning my injectors tomorrow Any other input would be helpful Thanks AFJuvat |
Sounds like a timing problem! Check to make sure the TDC mark on the cam (viewed through the hole in the cam gear cover) and the OT mark on the flywheel (viewed through the little hole between the engine and the firewall) line up.
Mark '86 944NA |
Thanks, will have them check that when I get the belts retensioned in a week
AFJuvat |
