gearbox mountings?
Everything was going so well and then it happened; selecting all the gears started to become very notchy, I noticed no difference in the clutch but if suddenly taking my foot of the throttle it felt like there was some movement in the drive train, although the gearlever was pretty stable. Usually if I have occasion to lift off things seem nice and solid. The car had done a 100 mile run and then quite a bit of town work before this happened, so was quite warm, in fact the clutch did judder a bit when pulling away but it sometimes does when the car is hot, a feature of this car, or so I've been told! Mileage is 88000. Would you guys please give me your opinions?
944s2
Old 03-05-2004, 01:22 PM
fast924S's Avatar
Send a message via AIM to fast924S
Check tranny mounts, Check tranny fluid, If you can find out if you have the updated clutch, Some of the older clutchs used a rubbed disk to stop vibration, urs may be comming apart
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 03-05-2004, 07:53 PM
